Originally Posted by sammie
[*] Get the special headlight removal tool from the toolkit stored in the frunk whose lid you can't open[*] From inside the frunk that you can't get into, use the tool to unlock the headlight assembly.
Everyone agrees the the design is less than perfect. One thing I do is keep the tool kit neatly rolled up behind and under the driver or passenger seat. This way it is accessible regardless of what you need it for. Also, once you do get it all open, reroute the emergency release to the front bumper where the toe ring goes. And another thing I have is a 5 mm socket in the tool kit that works better at releasing the headlight but you may not need it if the tool you have works okay. I learned all this from fellow forum members, a huge resource of knowledge.
