Old 05-04-2021, 06:27 PM   #4
Stl-986
take the engine cover off
look for the AOS
towards the back of the car by the AOS (under the oil fill tube) will be a vacuum line and the change over valve
What your mechanic should do (or you) is hook up a vacuum gauge to the vacuum lines, start the car and see what your vacuum numbers are. Believe it should be between 15-20".
With all that said it is most likely the solenoid but these ZF transmissions are pretty bullet proof.
I would still question the fluid being low. If it was, there has to be a reason why it was low. Also how you check level & fill it isn't the same as doing it on a manual. Still suggest doing a drain, filter & fill.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
