Old 05-04-2021, 11:39 AM   #1
elav
Inner door pull - microswitch removal
I did a search and while there are a lot of threads on microswitches and window regulators, I wasn't able to find the answer to this...
How do you remove the microswitch in the inner door pull assembly?
Background - I have determined that I need to replace the microswitch in the inner door pull that is on the passenger's side. I was able to find a complete inner door pull assembly at a junk yard and need to remove the microswitch from it and put it in my car. The door pulls are different colors so I can't just use the entire assembly. I know it is possible to remove the microswitch as Pelican Parts sells a replacement - 996-613-123-00-OEM
I don't want to break the microswitch figuring this out. Any help on which direction to pry it out (or if there is a retaining clip that I'm not seeing)?
elav is online now   Reply With Quote
