Thread: Ruroh Raggy!
Old 05-03-2021, 11:56 AM   #6
blue62
To JPF's reply you can get Marine grade solder connectors that you crimp on lightly then heat with a lighter or small torch.
They solder to the wire and also have heat shrink as part of the connector.
So if you use them your connection is soldered and also moisture proof.
Napa carries them.
