Old 05-02-2021, 03:58 PM   #1
911monty
911monty's Avatar
Interested in this as well as where the big wire on the alt goes to (ultimately the battery obviously, but does it to to the junction at the top of the engine, toward the firewall? Cable 19?
So is the small red wire going to the 40amp maxi fuse or relay support 2? 2 very different things.
The small red wire goes to the 40amp maxi fuse. The "Case at relay support 2" is a description for location. The large wire goes to terminal 30 at the firewall, then to the current distribution panel, then to battery.
