Thread: Jacked up???
Old 10-30-2006, 05:04 PM   #2
deliriousga
deliriousga's Avatar
I lift the front driver's side by using the rear jacking point and put the stand under the front jacking point. I go to the passenger's side and do the same thing lifting it a little higher and putting the stand under the front jacking point. Next, I go back to the driver's side and lift it from the rear jacking point to match the height of the passenger's side. Finally I lift the rear from the cross member mentioned before and put the last two jack stands under the jacking points.
1966 Wife White/Brown Top
