Old 04-29-2021, 07:30 PM   #15
ike84
Originally Posted by flmont View Post
OK..I shall start with that,.I have watched the filter every oil change and I don't see anything alarming But I have never pulled the sump plate, I even do random filter checks, But I still get that noise on a quick start,if I crank it over a couple times first and when it does start I don't really hear what I think is chain rattle noise but My Cam numbers are like 3.4 and 8.2 so I figure it must be that and that is why Iam trying to look at the guides B 4 I pull that engine Bc that noise make me crazy... Thanks for the info,.!!
I would install the revised pressure relief valve and spring while you're at it. Only takes 5 minutes.
I haven't seen anyone really comment on this but I would be curious to know if over time guys running the updated parts have less vc pad wear.
Sent from my POCOPHONE F1 using Tapatalk
