Old 04-29-2021, 07:11 PM   #19
Stl-986
What did you use? I`m thinking of just buying a generic keyfob and swap the board with the buttons into the original fob, or mate it with the key. Should be doable. Probably the immobilizer can be deactivated too, but I guess that`s not necessary if you move the modul from the key over to the new fob.
Huh?
You can't just swap anything. The pill has to be programmed to the car and the board that has the buttons also has to be programmed to the car.
As far as just adding keyless entry I only use DEI products in cars. Been using them for 20+ years. too many videos & instructions online on how to do this. Viper or Avital is what I use depending on the car and how many buttons I need.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
