Old 04-28-2021, 11:02 AM   #1
mmackie
Originally Posted by moosport View Post
you have water building up and its seeping through the cinder block wall since there is no place for the water to drain. The white stuff are just lime leeched from the cement. Hopefully its just rain from Spring. It will dry up.
You can put done some thick rubber perforated mats and walk on it.
Right this is what I suspected, i'm going to hit it with a pressure washer and see if it drys up when things warm up here
mmackie is offline   Reply With Quote
