Old 04-28-2021, 07:35 AM   #10
blue62
Ike
You have a bank 1 O2 sensor and a bank 2 O2 sensor so you will have bank 1 and bank 2 fuel trim readings.
Another thing you can compare to check cam (valve) timing on a flat six is to compare compression readings from one bank to the other.
Bad cam timing (usually late timing) will show a drop in compression.
I think fuel trims would be a better indicator if the cams are off by just a few degrees.
blue62 is offline   Reply With Quote
