Stalls at idle. Gas pedal keeps the engine running
Hi guys! My 99 2.5 stalls if dont hold down the gas pedal
Describing the storyline:
1-car running ok
2-changed oil and oil filter (diy) -> after that, rough idle and stalls after 20-30seconds
3-cleaned throttle body (diy) -> after that, car wont start without pressing gas pedal
4-replaced fuel filter (diy) -> same symptoms as #3
5-replaced idle control valve (diy) -> same symptoms as #3
I can keep the engine running as much as I want holding down the gas pedal.
No codes in durametric.
Additional info: the car has a coolant leakage (idk if it may affect)
What should I check?
