Suspension components were all replaced and the old ones are gone. The only suspension component I still have available is the original (blue) springs that come with the Bilstein PSS9 kit. I changed out the springs to the green Swift SPB spring rate ones, so have the ones shipped with the PSS9 available if anyone can use those
Window adjustment pieces are all gone I think, but I'll double check just in case. I may have the clock spring for the wheel. Is that the piece that goes right behind the airbag module? I'll take a picture and PM you if that's the one you're looking for.
