Old 04-19-2021, 04:00 PM   #2
Niceboxster
Originally Posted by ike84 View Post
You are correct - there is a sensor before and after the precat (on the header) but none that monitor the main cat (aka secondary cat). Id be curious how the figured that the cats are bad though...
Rumor has it that the most common cause of that code is a bad gas cap. You may wanna start there.
Sent from my POCOPHONE F1 using Tapatalk
Yea I'm not sure how they figured out it was the cats. If they just pulled the p0430 and concluded that it was the cats just from that I'd be pretty upset. I bought an installed a new gas cap because my old one had cracks in the o ring. I guess I'll just drive it for a bit and see if the cel turns off. Thank you for your help!
Niceboxster is offline   Reply With Quote
