Double din install, handbrake cable?
Just purchased a Sony Double din stereo. Looks like a reasonable straightforward job but some cables will need to be cut as Im ditching the lousy amp in the frunk. The built in 4x45 should be good enough.
Just a question regarding the handbrake connection specified in the manual.
It does not specify the reason for this connection.
What does it do and can I supply 12 v all the time instead of routing the cable to handbrake switch?
