Old 04-16-2021, 07:42 AM   #1
JFP in PA
Originally Posted by Vtx531 View Post
Getting the cat efficiency code for my left side cat.
I tried a spark plug antifouler (without drilling it out larger) and now getting a different code for that 02 sensor slow reaction. Maybe I need to drill it out 1/2” and so the O2 sensor can be inserted more fully. It was giving a constant low voltage reading (about .2v) the way I had the spacer compared to the .7 that would be normal.
Anyways, weird idea popped into my head. Can I removed the manifold and soak it in mineral spirits or something...maybe run water through it...and maybe decarbon the honeycomb to restore performance of the cat?
Buying a used cat seems like it would give me problems again soon as this seems to be common. New cat is too expensive. Used cat sounds like no good because less precious metals.
I suppose if cats could be cleaned then this would be a common thing to be done and everyone would already be doing it... especially since they are so expensive.
Other option would be RoW tune but I don’t know anyone that can do it.
Totally depends upon why the cat is acting up; if it is because of a sudden single contamination event, possibly; but if it is because of a longer term contamination problem, no.
