Cam sensor wiring
Still fighting the cam codes on my wife's 2000 2.7. Need some help. This is all for bank 1. I am seeing 12v on pin 20 @ the DME with connector 3 disconnected, car on & connector 1 & 2 connected. Is this correct?
I know pin 1 is ground & pin 3 is 5v, which are good all the way to the sensor. Should the signal pin have 12v when the engine isn't running?
It isn't a sensor issue as the sensor isn't even connected and it isn't a bad wire because the entire connector 3 isn't even connected to the dme. the DME is actually putting 12v on pin 20.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
