Old 04-16-2021, 07:56 AM   #1
Vtx531
Can catalytic converter be cleaned? Tried antifouler no luck Cel code
Getting the cat efficiency code for my left side cat.
I tried a spark plug antifouler (without drilling it out larger) and now getting a different code for that 02 sensor slow reaction. Maybe I need to drill it out 1/2” and so the O2 sensor can be inserted more fully. It was giving a constant low voltage reading (about .2v) the way I had the spacer compared to the .7 that would be normal.
Anyways, weird idea popped into my head. Can I removed the manifold and soak it in mineral spirits or something...maybe run water through it...and maybe decarbon the honeycomb to restore performance of the cat?
Buying a used cat seems like it would give me problems again soon as this seems to be common. New cat is too expensive. Used cat sounds like no good because less precious metals.
I suppose if cats could be cleaned then this would be a common thing to be done and everyone would already be doing it... especially since they are so expensive.
Other option would be RoW tune but I don’t know anyone that can do it.
Vtx531 is offline   Reply With Quote
