Originally Posted by Stl-986
since the seats are the same for 97-04 there is no reason this wouldn't fit. In fact it's the same bolt pattern 97 to at least 2010 since 987 seats fit in a 986 perfectly. When they say from, it means starting that year and up. So from 97 would mean 97 to 04 on a 986.
That is what I had assumed as well when I purchased it originally. Unfortunately the bar definitely will not bolt up to the frame since the holes for the bolts to pass through the bar are too small. To your point though the buckle itself and the wire that plugs in underneath the seat should work fine so I might be able to fashion a way to attach the buckle w/o the bar so it is secure.
