Thread: AOS delete?
Old 04-10-2021, 11:49 AM   #3
JFP in PA
Originally Posted by ike84 View Post
No, that's my point - delete the aos but keep an oil catch can it is place, thereby transmitting the entirety of the intake vacuum to the crankcase. No more obnoxious AOS to deal with, plus maybe a bit of extra power by increasing the vacuum and clearing crank case windage.
Sent from my POCOPHONE F1 using Tapatalk
That will still cause issues. The intake is often running at 24-26 inches of mercury, while the AOS is running at 5 inches of water vacuum. With one inch of mercury running at about 14 inches of water, the intake vacuum is many, many times the vacuum the that the AOS supplies, and just as too much pressure can blow out oil seals, too much vacuum can suck them in.
