Thread: AOS delete?
Old 04-10-2021, 09:41 AM   #1
JFP in PA
Extremely bad idea. Without the sump vacuum supplied by the AOS, you will suffer ring seal issues as the rings are low tension designs, the system will not flash off water and fuel that collects in the oil, and you run the risk of blowing out the cranks shaft end seals due to pressure build up (both seals are just pressed in and have no other retention devices, so very low pressure is enough to push them out).
