Old 04-10-2021, 09:04 AM   #24
dunl
if the car starts and engine runs, then drive it. will not run well and expect you would spray oil, not have any vacuum but if you could move the car. If you dont want to replace it with a factory one then make one from the hose you have that's broken, pictures are right above.
That would work. I just don't want to damage the car by not having it connected....could be possible to block it off before moving it I guess in the short term.
Not necessarily planning to NOT replace it with stock, just under a time limit here.
dunl is offline   Reply With Quote
