Thread: AOS delete?
Old 04-10-2021, 04:09 AM   #1
ike84
AOS delete?
So I just had a thought and am curious as to what everyone thinks. I recently read an article about dry sump system setups in nascar and an engineer had stated that they look to get a full 1Bar of vacuum on the crankcase with their system - not only to scavenge the oil but also to evacuate crankcase windage which they estimate increases hp by 3%.
I personally run an oil catch can between my aos and the intake, because I'm sure it will fail again. I think jaay runs the same setup. But now I'm thinking - should I remove the AOS all together and run lines straight into the catch can? That way we get the advantage of windage reduction. I'm not sure how quickly the catch can will fill up though.
Thoughts?
Sent from my POCOPHONE F1 using Tapatalk
