Old 04-09-2021, 08:01 AM   #5
sfkjeld
sfkjeld's Avatar
I was going to confirm this as well. I just replaced the rear tires with Michelin All Season Pilots, on my 2000 stock base 986. The fronts have 50% wear. Replaced the two rears because I had a defective rear tire and Costco’s warranty includes a free 2nd tire. “Single axle warranty”. The tire pressures are 29 front, 36 rear. Anyway, since replacing the rear tires, the handling seems to have changed. The backend feels squirrelly. So would tire pressures change when there is this disparity in tire wear? I was going try increasing the rear pressures to reduce sidewall flex. But really, I haven’t a clue. It’s also hard to do much testing since it’s nearly impossible to find a working and accessible air compressor in these parts.
sfkjeld is offline   Reply With Quote
