Old 04-07-2021, 06:20 PM   #1
tpodowd
Originally Posted by elgyqc View Post
Personally I have never had a problem with fuel going so bad after one (or two) years that the car won't start. If the car was running fine before the problem is probably fuel or spark. Is it possible that you have a rodent problem? There are a lot cases of rodents chewing through wire insulation leading to electrical component failure. Check fuses.
I haven't seen any rodents around the garage (or house in general). It's pretty clean with nothing really lying around to attract them except the car and some bikes. But anything is possible I guess. I'll check the fuses. It is a good idea ot check them anyway although the car cranks just fine but fails to catch.
tpodowd is offline   Reply With Quote
