Originally Posted by Blue99
Check the fuel pump is working I’ve just had exactly the same thing
Try pushing the car vigorously back to front like you are trying to push it up a speed bump. You want to introduce a wave into the fuel tank.
This problem can occur when the contacts inside the fuel pump motor get corroded. Getting the fuel to move can just slightly turn the impeller and get the fuel pump to make solid electrical contact.
