Old 04-07-2021, 12:09 PM   #19
john12312
2002 Boxster S
A few years ago after lowering the front of the engine to replace the water pump I was not able to start the engine and got a very strong raw fuel smell..
The cause ended being the engine harness connector, right behind the firewall (987CS) as it became partially disconnected, Brad Roberts kindly suggested to check it and the engine started immediately afterwards
Good luck!
Is that the same as the VarioCam Harness connector?
john12312 is online now   Reply With Quote
