Old 04-07-2021, 05:03 AM   #2
elgyqc
elgyqc's Avatar
Personally I have never had a problem with fuel going so bad after one (or two) years that the car won't start. If the car was running fine before the problem is probably fuel or spark. Is it possible that you have a rodent problem? There are a lot cases of rodents chewing through wire insulation leading to electrical component failure. Check fuses.
Grant
