Old 04-06-2021, 06:26 AM   #5
Rob175
Rob175's Avatar
Those pictures look like there was MORE in there than your typical road debris. Looks like critters like mice, rats or even birds made a home for a good long time.
I cleaned mine without removing all of those parts on my 98'. Did I clean it out 100%, probably not, but maybe 80%... but my temps are all "normal" year round.
I accessed through the little front vents using a combination of first a flexible tube super powerful vacuum and a bent wire tool. After I got most all of the visible leafs, cigarette butts and paper scraps I then switched to a water spray, again with a flexible tube to direct the water.
The debris I removed was on the driveway after the job was done...all temps normal and it took a couple of hours. I suggest you try a similar task first. I don't have a lift, and I really didn't want to disassemble the front end, because I don;t think I have much if any debris BETWEEN the two radiators....I could be wrong but the heat and AC work great and as I've said my temps are all normal.
Rob175 is online now   Reply With Quote
