Old 04-06-2021, 07:14 AM   #3
Rexracer
Originally Posted by Stroked & Blown View Post
I had a leaking clutch hydraulic line that caused similar symptoms. In my case, there was clutch fluid leaking in between the fender and body, just inboard and aft of the front wheel arch.
Could also be a worn master or slave cylinder, but I’d start by checking the line and doing a flush.
Thanks for the input! Will check it out.
Rexracer is offline   Reply With Quote
