Old 04-05-2021, 08:52 PM   #1
Homeoboxter
If it`s the IMS, then why did the pressure warning come up? If you indeed killed a bearing you should be able to find bearing material in the engine oil. Hopefully that`s not the case... If it`s an IMS failure you should be seeing metal debris in the oil anyways, so that`s what I`d look at first.
