Old 04-05-2021, 07:47 PM   #11
blue62
Blue, could you please provide more details on how do you test a restricted cat using a vacuum gauge?
I bot a digital manometer (JFP's suggestion) to check the vacuum on the block and curious how you use it to check a congested cat.. thanks!
A digital manometer is different then a standard (old school) vacuum gauge.
So it will not work to check a restricted exhaust system.
With a standard vacuum gauge its the action of the needle on the gauge that is important.
So you do a "Snap throttle test" and a "Hold RPM test".
Cats have to be hot Ect. Ect.
It will be easier for me, and probably more informative for you if you google vacuum gauge testing catalytic converters.
You will find all the info you need to do the test.
Edit: A standard vacuum gauge only costs around $15.00-$20.00 and as I stated in my other post very handy tool.
There is lots of info on using them on the net just have to search around.
