crankshaft bearing case.
On stripping yet again my crank case I have found ATF & assembly fluid seeping out from 6 of the main bearing housing...between the steel insert & the alloy casting on the bottom half of the assembly...on close inspection with a magnifying glass it looks like the insert has broken away from the casting... on checking on e-bay for second hand one,s I saw several which looked the same...anyone heard of this before.
