Wd40 dry lube will fix this. It's liquid ptfe and safe to use on electronics. It's great stuff, I had the se problem with my door and ignition tumblers when I first got the car, fixed them right up. You can also remove the tumblers and flush them with brake cleaner to remove old debris and then lube them. You'd be surprised how much gunk you'll get out of there.
Sent from my POCOPHONE F1 using Tapatalk
