Exhaust smells sweet? Is that at the tailpipe or just overall around the exhaust?
Think you just had an air pocket or you over filled. I would get it up to temp at idle and check level...on a level ground that is or with only the rear lifted.
You could also rent a coolant pressure tester and see if it holds pressure. You can do this with the engine off at least.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
