Old 03-27-2021, 07:30 PM   #1
Gjohn3707
Gjohn3707's Avatar
2001 base gear oil change
Changed my gear oil to new porsche gear oil. I didn't know if it was ever changed so I read all the forum articles I could find. I decided to drill the 2" hole instead of removing the plate. Getting the fill plug out was really difficult, thanks to the forum for the warning. A breaker bar and 2 foot pipe was required. It made a loud snap when it yielded, I thought I broke it. The hole was easy to drill and the dark oil drained. I fill it wit 2 liters then measured .25 liters into the funnel. The 11mm dipstick was used to check. I only had one drive but the cold second gear shift was easier, and smooth when warmed up. Only a few tiny magnetic particles were in the bottom of my bucket. The forum has dimension to locate the drain hole in the pan. I found the tools at local parts stores.
2001 Seal Grey Boxster Base
Gjohn3707 is offline   Reply With Quote
