Old 03-25-2021, 05:15 PM   #2
78F350
Motorist & Coffee Drinker
78F350's Avatar
Originally Posted by DarrenD View Post
Thats perfect, thank you. Now I need the route the hose takes from the top of the oil cooler to that hose.
The hose just crosses the top of the engine underneath the throttle body and connects to the area I pictured.
...Unless you have a 1997. A 1997 2.5L will require a little bit of adaptation because the original heat exchanger didn't have the purge line. Air in the system in those is purged from a tube on the front of the engine. In that case, you can plug it or install a "Y" to join the hoses.
