Old 03-25-2021, 03:23 PM   #3
Starter986
1998 Boxster Silver/Red
Originally Posted by Chboro View Post
Last weekend I installed new spark plug tubes and spark plugs. Driven it a couple times since and when I get home I think I'm smelling plastic or something similiar that I haven't smelled before.
Is that fairly normal after installing new spark plug tubes?
Did you repolace the old tubes because of a leak... or just as preventative maintenance? I'm thinking the o-rings that you slid onto each tube might have not properly seated... and is allowing oil to pass through.
Have you gotton under it to see if any of the tubes are leaking? That might be the culprit.
In any event... report back what you find. Might help someone down the road, literally.
1998 Porsche Boxster
