Old 03-25-2021, 03:11 PM   #3
Starter986
1998 Boxster Silver/Red
The coolant vent hose goes from the heat exchanger to the coolant expansion tank. It is the top hose in the stack of three under the oil filler tube.
Most cars I've seen have a quick release connection in the middle of that hose, so the portion connected to the coolant tank may still be there.
Question:
The coolant line running into/out of the control valve (928-574-573-03-M53) for the transmission cooler. Where does that hose fit in with the coolant tank? Thank you.
1998 Porsche Boxster
