Old 10-29-2006, 10:49 AM   #5
MNBoxster
Originally Posted by djomlas
found it, thx guys. there was a little cap on it and i didnt see it.
got my convertible top to work too
now my window is somehow stuck in the down position, motor is working, but making this weird mashing noise, and i got the door taken apart, and i can see all these little metal particles all over. anyone got a suggestion for this?
Hi,
Unfortunately, your Windor Regulator is kaput, not uncommon. You may also need a new motor if the metal shavings are from the splines of the motor's output rod and not from the Regulator.
You do not mention which window and the parts are Lft/Rht specific.
Window Regulator - PN# 996.542.075.04 (Lft) - $205.00 PN# 996.542.076.04 (Rht) - $205.00 List.
Window Motor PN# 986.624.101.02 (Lft) - $200.00 PN# 986.624.102.02 (Rht) - $65.00.
This a pretty easy, though involved, DIY repair. But, you'll need to disassmble the current window to ascertain which parts need be ordered. Be sure to disconnect the battery and wait 5 min. to insure that the side-impact airbag is deactivated before you begin. Hope this helps...
Happy Motoring!... Jim'99
