Old 03-19-2021, 04:13 PM   #2
rfuerst911sc
Hit it with Kroil or PB blaster . Tap with a hammer a few times then try the vise grip . If that doesn't work try a sharp chisel on the edge of the plug . You want the chisel to dig into the plug but NOT the engine sump plate . Hitting it in counter clockwise direction should get it to turn . A little heat will help also . Good luck
rfuerst911sc is online now   Reply With Quote
