Originally Posted by AXCM2
Thanks for the tip! I will definitely order it.
Just FYI. The hose you need is not the hose that goes to bank 2, although due to age it could be replaced. The hose you need is the short hose that goes to the manifold at the TB. Pelican has it listed as needed part with the AOS. I just saw you have a MY2000. You may not need anything. The hose was needed to convert flat AOS on the earlier cars to the new style AOS.
