Old 03-18-2021, 02:24 PM   #1
rfuerst911sc
Mine does not have a hump or bump in the middle , it may have been tweeked during shipment . Also because my Boxster is an S model with the third radiator I cut out that center section for air flow . I used a hole saw about the same size as the opening and drilled the two ends . Then cut out the piece in-between with a air zip wheel . A little filing and sanding and good to go .
rfuerst911sc is online now   Reply With Quote
