Originally Posted by blue62
Simplest things first.
are you sure the bleeder valve is in the down position?
If yes take it apart again and make sure you reassembled it correctly.
Took apart again. Everything seemed in order... cleaned around new o rings. When cold still had difficulty holding pressure. If I pumped up to 4psi I could hear a high pitched squeal coming from around bleed valve housing.
Nevertheless I started the car and once it began to warm up, I was able to pump pressure tester to 5-7lbs and it would hold pressure. As engine warmed up pressure increased as well.
Wondering if I’ve finally seated the bleed valve correctly.
Popping up tab on bleed valve reveals a burbling sound which goes away with tab down. System still holds pressure and does not leak out overflow valve.
Despite having an .04 cap I think that is now the culprit.
Off to dealer to grab new cap. Fingers crossed!
Many thanks for all of the great suggestions.
Dave
