Old 03-18-2021, 08:44 AM   #12
blue62
Originally Posted by The Sandman View Post
Update: replaced bleeder valve, system still holds no pressure (using pressure tester) and I can still hear air seemingly near bleeder valve during pressure test. O rings are on it properly. System also dumped a ton of coolant through overflow again today after a spirited run.
No evidence of coolant in trunk. Is there anything potentially serviceable underneath bleeder valve? Stumped on this one.
Dave
Simplest things first.
are you sure the bleeder valve is in the down position?
If yes take it apart again and make sure you reassembled it correctly.
blue62 is offline   Reply With Quote
