Old 10-28-2006, 02:35 PM   #22
CJ_Boxster
Send a message via MSN to CJ_Boxster
Ohio, I already told you, your crankcase if under vacum during idle, if your oil filler tube has come off, your vacum will not be too good, and your boost will lag. Your intake manifold connects to your engine crankcase and sucks the bad gases that the oil creates while hot SO if you have anyhoses from the block that have come off, like the oil filler tube or forgot to reinstall your oil dipstick, then you will have a vacum leak under idle and boost leak under acceleration. MYSTERY NO MORE!
Wish my car was running like champ.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
