Old 03-14-2021, 05:52 PM   #26
porschefan76
porschefan76's Avatar
I would clean it all up and let it dry out and then check to see if it's still leaking. You could have had too much in there and this from overfill...but that should have gone out of the car, not in the trunk. I have seen much worse with a bad coolant tank. Could also be a bad coolant cap. Once it's all cleaned up and dry you can just start the car and then watch to see if it leaks again.
Hey, thanks for the reply! Well , the weirdness I found with my borescope and the fact that it's pretty well discolored, I think I'm just going to replace it, but I take the point. Maybe I'll take the car out tomorrow and see if it continues to leak in there. Thanks again!
porschefan76 is offline   Reply With Quote
