Originally Posted by Stl-986
Failing/failed AOS.
Also check for oil on the top of the engine if you see some it could be a few other things that wont be fun to replace while it still installed.
+1 on the AOS. Your spirited drive surely contained some corners where one might imagine oil following those G forces. When the AOS is not in top shape, some oil gets piped into the intake, burns during combustion and smoke results.
