Old 03-14-2021, 04:18 PM   #72
Stl-986
I would clean it all up and let it dry out and then check to see if it's still leaking. You could have had too much in there and this from overfill...but that should have gone out of the car, not in the trunk. I have seen much worse with a bad coolant tank. Could also be a bad coolant cap. Once it's all cleaned up and dry you can just start the car and then watch to see if it leaks again.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
