Old 03-13-2021, 05:00 AM   #2
ike84
Also suggest calling around to dealers or see if yours will price match other dealers. I ordered a fob & key from Silver Springs, they were cheaper then everyone. Then took it to the dealer to be programmed. Fob should run you under $150 & key should be under $60 (think it was much less can't remember). Less then 1 hour labor & your tow. I would get 2 keys if you can swing it.
the other option is to find a DME/Immobilizer with keys on ebay. That's what I did for my 2000 and it was under $300. I already had 2 keys but the fob buttons quit working some time ago. No programming necessary. You would still need the key blank, but any dealer can order that & ship it to you for you to put in the fob at home.
So if you switch out one then you must switch all of them, right? If you need a new dme then you must buy it with the matching immo and keys? Or do the keys just sync with the immo and the dme can be swapped separately?
Sent from my POCOPHONE F1 using Tapatalk
