OK I think you have me convinced. If the standard thing to do is remove outer seal then I'll so that. I also tapped the center shaft thing in and sucked out all the oil in the shaft. Only had about 1 once in there, but it was very dark and had an odor to it. Thanks for the info.
2000 Boxster S
